09 swingarm??
09 swingarm??
I have an 06 swingarm on my 03 636. I havent seen anything about the 09 swingarm. Will it fit?
idk for sure but I would think it would. the 07 08 zx6r frames are a close match to the 09s.....buy one and try it before winter is over! lolol
Looks like that's my only choice
Originally Posted by TL MILLER
It will fit
Originally Posted by JohnnyP
It will fit
Thanks
Your the one person I was hoping would chime in.
So just one dust seal swap? All wheel spacers the same size as the 05
Thanks
Same as 07/08, slightly different spacers then the 05/06 +/- 2mm in each direction.
Swingarm bearings, pivot shaft, rear shock, and shock linkages are all the same as 07/08 so it will bolt on just like a 07/08 swingarm
