Threads: 23
\r\n \r\n i dont know about the 14 rotor but i do know the zx11 d model rotor bolts right up but i dont know if your caliper is far enough out , if not the newer zzr rotors are a little smaller than the zx11 and they bolt up too\r\n
Threads: 11
\r\n \r\n \r\n \r\n \r\n Originally Posted by old man roger\r\n  \r\n \r\n i dont know about the 14 rotor but i do know the zx11 d model rotor bolts right up but i dont know if your caliper is far enough out , if not the newer zzr rotors are a little smaller than the zx11 and they bolt up too \r\n \r\n | \r\n
what year\r\n
Threads: 14
\r\n \r\n \r\n \r\n \r\n Originally Posted by mdub4life29\r\n  \r\n \r\n what year \r\n \r\n | \r\n
lol we were just discussing this the other day. think it was 93-01 but nobody was really sure\r\n
Threads: 10
\r\n \r\n 14 rotor does not bolt up, tried and it doesnt fit
\nFor your windscreen 05-08 are all the same\r\n
Threads: 20
\r\n \r\n \r\n \r\n \r\n Originally Posted by MikeM\r\n  \r\n \r\n lol we were just discussing this the other day. think it was 93-01 but nobody was really sure \r\n \r\n | \r\n
93-01 ZX or ZZR1100 100% sure will bolt up on the rear Kawi wheels\r\n
Threads: 16
\r\n \r\n sick! i\'ll have motomaster send me a zxr400 rotor then.. which years? and then offcourse i should get the hohey additional bracket, right?\r\n
Threads: 10
\r\n \r\n \r\n \r\n \r\n Originally Posted by da Liks\r\n  \r\n \r\n sick! i\'ll have motomaster send me a zxr400 rotor then.. which years? and then offcourse i should get the hohey additional bracket, right? \r\n \r\n | \r\n
That wont work because the Hohey brackets are designed for 250mm rotors...If you use his brackets with a 240mm rotor you will still have to trim pads and wont get full contact
\nIf you want to stick with your Hohey setup, and get a bigger rotor without having the buy the expensive Star rotors. Get a OEM or Motomaster ZX11 rotor(250mm) and the adapter brackets...\r\n
Threads: 10
\r\n \r\n \r\n \r\n \r\n Originally Posted by JohnnyP\r\n  \r\n \r\n That wont work because the Hohey brackets are designed for 250mm rotors...If you use his brackets with a 240mm rotor you will still have to trim pads and wont get full contact \n \nIf you want to stick with your Hohey setup, and get a bigger rotor without having the buy the expensive Star rotors. Get a OEM or Motomaster ZX11 rotor(250mm) and the adapter brackets... \r\n \r\n | \r\n
\nwhat about f4i with fti dual quad bracket? is there a rotor i can use?\r\n
Threads: 10
\r\n \r\n \r\n \r\n \r\n Originally Posted by i_throw_nickels\r\n  \r\n \r\n what about f4i with fti dual quad bracket? is there a rotor i can use? \r\n \r\n | \r\n
Not without moddifying your FTI bracket to accept a bigger rotor
\nThis is how I modded mine
\r\n \r\n I\'m running the ZX-11 rotor with my set up.
