0
i have a 04 r6 and i put it on its cage today to do donuts when its on its side but after that the bike wouldnt start..... i checked the fuses with a test light and cant seem to figure out why it wont start.. maybe its the tip over sensor??? but i have no idea where that is.. HELP
Threads: 23
0
sounds like the bike isnt charging ..push start it and check the voltage at the battery , should be 13.5 or higher when the bike is running and a little above 12 when it's not running ..
you might have to give it a rev or two to get every thing charging ..
Threads: 23
0
check to make sure all the cable are tight too
0
My r6 did the same thing and it was the rectifier. It rode fine that day and I went to visit a friend at his shop when I left I rode a long as wheelie down the block, set it back down to turn right then made it a little ways down the street and that was it I fried the rectifier. Check the wires going into it to see if they look burned. You can get one cheap if it needs to be replaced
0
my bike still isnt running i havent checked the rectifier yet, i will when i have time and how do i check the voltage for the batteries? i dont have a volt meter or anything like that all i got is a test light lol....
Threads: 3
0
u need a voltage meter. they arnt that expensive. get one
