Vortex Front and Rear Stands- Starting at $109 Shipped
Click Link to go to Naarden Online Store: http://www.naarden.biz/products.asp?cat=484
from October 21-Oct 28.
Celebrate Vortex�s AMA Superbike & Sportbike Titles
Tubular design to ensure stability measuring at 1 �� diameter with four 4�� soft wheels wheels with bearings for easy pivoting motion.
Axle and wrench holders located on arm to help keep part clean while removed.
Supports from steering neck to allow easy access to front wheel and other components.
Lifting arm is removable and stowable for a safe working environment.
Easy disassembly for easy shipping and storage .
Font stands are not to be used without a rear stand for stability.IMPORTANT: Bike specific pins are required for proper fitment into the lower triple clamp. Please use drop down menu for your bike.See FRONT STAND PIN APPLICATION CHART for correct pin sizing.All stands come with pin FP050, if needing adapter FP051 or FP052, select it in the option below.
Group BUY orders will be shipping out November 2
so with that vortex rear stand can u by those front fork stand converts to save money
Originally Posted by SimpStunts
whatcha mean? The stand converters only pick up the front end off the forks, good for most things but if you ever take out your forks you need the pin style.
The converters fit into the rearstand.
Originally Posted by Naarden
u answered the questin with the pin thing sorry I ran around the block to ask the question
make a bracket to hold the trees
