Mitty vac break bleeder
so i bought one used it once and i am not sure if i like it. its easy to use but i burn and churn through canister of brake fluid. my question is when you pump it from the handgun and it goes into the little resovoir cup can i use what was bleed out from the cup as long as is its new brake fluid? it seems like such a waste not too. will i be contaminatin the fluid if i do this?
i normally dump mine but really as long as you wipe off the bleeder and clean out your cup good i see no reason to not use it.
yup i always reuse mine and never have had a problem
sweeet thanks for the tips
reusing the break fluid that comes out usually has air in it lil bubbles plus it usually pulls old fluid out with it
thats what I think
