What gearing do you have on your bike?
I'm running a 50 tooth on my 03/04 636. But I have been considering going up to a 55 or maybe even a 60.
Threads: 9
55 0n 03 04 636..Money
edit: my bad didn't see it was in female stunters
Threads: 4
I run a 60 on my 636, it was hard to get used to because I rode stock, then 54 on my F4i, but I like it now.
Why are you wanting to change?
Threads: 13
64 and 3 down on my f4i ,,, thats money !!!!
Threads: 22
i run a 50t on my 636 and real low idle, between 1900 and 2000 haha i should go up though
Threads: 9
on my 03 636 I run a 52 and 2250-2500 rpm. In the end though I think gearing and rpm is dependent on your body weight, position, and amount of aggression you ride with.
60 and 2 down !!! F4I 4 life !!
i think i'm 50 or 52, i'll double check when i get home, and i run my idle higher at 3-3500, i run even higher depending on what i'm doing.
Threads: 6
60 tooth on rear on my 03/04
54 rear on my k3 fixxer 600
