04-05-2010, 05:11 PM
changed the key switch, not that
checked all fuses, not that
what else can i look for?????
01 f4i no spark
checked all fuses, not that what else can i look for?????
04-05-2010, 05:24 PM
Do you have injector pulse? Some hondas use one power wire to run a few things and coils and injectors are one of them. Oh! It also runs the fuel pump. Is it priming?
04-05-2010, 05:27 PM
04-05-2010, 05:35 PM
pulse generator! its behind your right side engine case.
04-05-2010, 05:38 PM
04-05-2010, 05:39 PM
ok be back in a few
04-05-2010, 05:48 PM
ok dont know if this will help but i just pluged in the gauge there is the neutral light and a red light, under that the oil light is blinking. any ideas???? and how do i check the codes???
04-05-2010, 10:29 PM
ok, i have no spark...very minimal voltage to my hot side of the coil and no ground on the ground side, however i have .4 ohms of resistance from the coil ground to ECU ground...stator checks good continuity and good output...i think anyone know what the spec is for stator output on this thing??
also from what i said does this bring any sugg
« Next Oldest | Next Newest »
