GP tech hand brake/clutch reviews
cool thanks
Quote Originally Posted by mb32
rsc clutch and magura hb. everything else is poop!
magura is junk fyi. brembo
ill never use a magura so my brake fades away and i have to pump it every time i ride...
Quote Originally Posted by RustyStunts
generally spoken, false info... have been using magura's?moto-masters (same thing) for 3 years straight, never a problem, except when not bled correctly..
I have the same setup I love mine It's dope!
Quote Originally Posted by da Liks
daliks. what do you run for a brake setup? what size master and what bracket?
this year i have been using:
12mm Motomaster/Magura master, 80" Motomaster steelbraided brake line, Hohey DC 4piston bracket with a rightside Nissin Caliper, Motomaster Rotor, SBS carbontech brakepads, Motomaster brakefluid. For the footbrake, stock kawi caliper, SBS carbontech brakepads,MOtomaster steelbraided brake line.
for the front: Brembo 19x20 master cilinder, Motomaster lines and fluid, MOtomaster Rotors, stock calipers, SBS Roadsinter brakepads.
for the stoppiebike i use the same, except i use a gsxr SRAD 16mm axial master cilinder..
My man That's some truth right there.
Quote Originally Posted by Outlaw Society
no it's not.. athough i DO agree on the rsc part, the HB is waaaay personal. and "magura" can mean anything.. 11mm 12mm 13mm even 16mm (i have one), billet or forged etc.. and every single one feels different. so dont generalize!
cool.. thanks for the info man.. i'm gettin rid of my dual single pistons in favor of a four pistons setup. i was thinkin about continueing to run my brembo 16. do you think i should get a 13 instead? my problem is my current brake is really strong, but has an on/off feel. what you think?
Quote Originally Posted by lee majors
the bigger the calipers the more feel you will get and the smaller the master the more feel you will get ..
