My sickest trick, filmed last week in Neuss.
thanks beul and Stuntnick!
[ame="http://vimeo.com/14009204"]Glenn's Sickest Trick on Vimeo[/ame]
Nice!
That kind of a trick is bound to catch some attention!! haha
damn vimeo.... i cant see them at work
Threads: 28
is it in neutral and on the limiter??
cool trick... but do it in gear on the limiter!! be sicker!
Threads: 26
thats a crowd pleaser rite there, nice!!how do u stuck your throthle open!!!????
Guru
yep in neutral, a beating for the bike but a pleaser for the crowd
I actually wanted to do a hc burnout after the drop, but then I would need some sort of thumb shifter to put it in gear!
smokey636
push the handle rubber to the inside then lock it in place with a zippy-tie
nice. Like the Type O Negative too.
good stuff Multiboy!! dangerous part is that you dont want to kick it in gear while doing the elevator
Threads: 9
ummm i hate to be a hater but a $20 throttle lock doesnt make a elevator to acid drop a whole lot cooler
Threads: 66
Guru
+1..
