01-31-2010, 11:44 PM
This thread is about the tear down & rebuild of the motor from my 89 lx that I'm swapping into my '66 FORD FAIRLANE
The donor is a 89 lx with 115k. I knew it would need some cleaning, refurbishing so I did a comp test a couple weeks ago and got great results in all 8 cyls (135psi+) and the AOD was rebuilt 3k ago so I decided just to freshen up the motor instead of a complete rebuild. I am also adding GT40p heads(explorer heads),explorer upper/lower intakes as well as a trick flow cam/springs.
We'll see how tomorrow pans out and try to get paint & some assembly done!
