Bike Problem - Any Suggestions??
\r\n \r\n just like me man, i had the money for a newer model but i picked my fav year, and ive seen pics of your bike and its fuckin sweet.\r\n
\r\n \r\n thanks man, if you ever have any questions feel free to hit me up, if its been broke i\'ve broke it! or if its been rigged.. or zip tied.. you get the point lol\r\n
\r\n \r\n i def will, my bitch is on both stands right now so in about a month watch out for fixing tips and broken bone cry-outs.\r\n
\r\n \r\n \r\n
\r\n \r\n Maybe a stuck valve. Just maybe..\r\n
\r\n \r\n id say its something simple like a bad wire or water in gas.\r\n
\r\n \r\n \r\n \r\n \r\n
\r\n Originally Posted by Highstyles\r\n View Post\r\n
I will let it run and check to see what cylinder it is then swap them and do it again and see if thats it..
have you had time to swap them yet and see if that was it\r\n
\r\n \r\n bump for update styles!\r\n
\r\n \r\n If you do not want to burn your hands spray some brake cleaner or some spray onto each cylinder on the header its suppose to vaporize quick if you see it running down the header and the fluid doesnt vaporize then that cylinder is running cold. Another thing you might want to do is take off the spark plugs and read them to see how each cylinder is running. They should be a brownish color at the ends if one looks more whiter than the other then that one is running too lean and you might have a problem with your injector. It is really easy to get them dirty. If all your plugs look the same color then you might have a electrical problem in your ignition system I would still do a compression test and then a cylinder leakage test then you get that out of the way. dunno if that helps\r\n
ok, 07 zx6r first start idles up runs good for a minute or so then seems to drop a cylinder.. almost runs like theres water in the tank, but it ran fine the night before, loaded up in the van and went to ride the next day and it ran like shit.. if you rev it up and pick up the cylinder you won't loose it until it idles back down.. Any suggestions?? I ordered a manual cam chain tensioner ( not that i think thats it, its just time ) and plugs.. not sure what else it could be.. bike has 5000 miles on it, changed plugs at 2500
