03-02-2012, 05:42 PM
Yea man if you ever snap a bolt again go get you a bolt extraction kit. That will get ya fixed up. Like mentioned check the water pump housing to see if it is in there, you could drop the pan to be sure, just R1 pans can be a bitch because of the breather hole, there is a little copper piece of tubing that sits in the oilpan sandwhiched between the pan and the inner lower case. That thing if those orings don't seat right will leak oil when you put the pan back on. So be careful with that. If you can't find the o-ring you can either order it, or hit up ace hardware they have a good selection of o-rings and you can probably find something that will work though you wold want to take the pump and that elbow with you to make sure. I've had to do that with things like o-rings on injectors to make sure the injector and fuel rail would mate up and seat right. As far as flushing the motor it really depends on how much was in there, you could do something like a kerosene treatment, but really the best thing would be to let the bike set a few days for everything to drain into the pan, get a cheap fram filter and put new oil in after the draining. Run it for about 5 minutes after the engine reaches operating temp this will help vaporize any remaing water. Then with some insulated gloves and being careful drain the oil while the motor is still hot. Let it cool and settle for a couple of minutes but no too long. There used to be some stuff I've used once to help remove moisture and crap from the motor I got from autozone so if you wanted you could ask them and put some of that in the oil while doing that oil flush. Then after you drain check the oil see how bad it looks, if it looks like it needs another flush of oil, do it. Make sure when you are done to put another new usused filter on. Should be good to go after that. That's how I've handled bad leaking headgaskets that made milkshakes in the past just to prevent corrosion and unwarranted excessive friction due to the water.
