New stunt parts
New stunt parts
Quote Originally Posted by anarchist35
$450 too much for a steel sub is laughable. not to be rude, but have you looked at metal prices? are you aware of all the fabrication and r & d? coming from a do-it-yourselfer, i built my own for my f4i, and at the time it was TOTALLY worth it. i still run it, but if i had the option to buy a legit one for $450 i would've been all over it.
This is why we quit making them. We were losing money on them at 400.00 and people still thought they were over priced. The amount of work that goes into one, they should sell for 800-1,000.00. If not more. Stunt parts are way under valued, but we can only charge what people will pay...
clip-ons that have an offset riser so they come off directly above the triple. like how dirt bars sit directly atop the triple, but with clipons. 5-7 degree up angle preferred.
just don't blame me when everyone wants them
Quote Originally Posted by lee majors
What would be the benefit? The clip on tubes would have to be really long also.
Quote Originally Posted by SickIan
no reach to the bars (for normal riding). the clipons would be long but (depending how you engineered them) the brake master could mount toward the inside end of the tube, above the fork. that way the clipons wouldn't protrude past normal clipons.
just a thought. nobody makes anything even remotley similar. you always have to sacrifice..too close..to far forward..too long (bar end to bar end). you get the idea.
You mean something like darwin bars, but with clipon tubes instead of a cutdown dirtbar?
Quote Originally Posted by Larse
kind of. the bars wouldn't have a bend though, and would sit higher above the fork caps.
Maybe I'm missing something but why can't u just put fully adjustable clipons on to the side of the fork and raise them up a few inches and you'd have same result. Your clipon bar would be derictly over ur forks
Quote Originally Posted by stlwade
if i'm picturing that right, that would still render anything above the fork unusable for control (brake master,etc) mounting purposes, so the clip on would have to be really long to accomodate that stuff.
i'm no engineer so bear with me. simplest design i can think of..imagine a convertibar with an offset bend in the riser. i'm sure their are way better ways to engineer them, or maybe not, but i'm just throwing that out there to give you an idea.
A top billet triple with fluid res.built in to do away with hoses and plastic res.
Quote Originally Posted by JBoom
he did it already on the prototype. it didn't work
