06-18-2014, 01:38 PM
Tricky technical question
06-18-2014, 01:45 PM
The start is the most important part. Thats where the most speed is lost, and thats when the angle changes quickly. But the relativity to balance point isnt even the biggest benefit, traction is. Obviously the front will have more traction since the bike is already leaning forward a little. More traction means you can hit the brake harder at the start, and get it up quicker. Up here in the north, thats a big deal in the winter.
06-18-2014, 01:47 PM
LOL I don't even have a Facebook you fotf faggot so not sure what your referring to and furthermore the only "lil bitch" on here is you posting up fake vids and going on how you make 120k$ a year yet you own a bunch of garbage bwhahaha. I think I just got dumber replying to you as well. Bang head to wall.
06-18-2014, 03:02 PM
Bill D explained his suspension set up as having soft compression so that the bike dives quickly and stays compressed throughout the stoppie. But he didn't mention anything about ride height in the front or rear. But I think you're right about lowering the front end and having less compression during pop up
06-18-2014, 03:08 PM
^^ that would make sense just like raising the rear, if you only lower the front the rear is actually higher and will lift easier. I had a 636 lowered just slightly and it hated stoppies.
All in all no clue i'm only here to read loogies comments lol
06-18-2014, 03:27 PM
we can assume that the contact patch will always be directly below the axle. The rake angle can change depending on ride height in front or rear, but the angle between forks and frame will always be the same, so once the rear tire is off the ground, rake angle doesn't matter any more. I drew some lines on this picture to explain why I think BP would be lower with a raised front end.
06-18-2014, 03:34 PM
so it sounds like a bike with a raised rear and a lowered front would come up easily and have a super tall BP
06-18-2014, 04:23 PM
06-18-2014, 05:47 PM
What do you mean by changing the suspension. You mean the settings or height
06-18-2014, 08:50 PM
Yah the height. Sorry
