20130904_114027.jpgHere is my Hohey Big Rotor setup. 06+ FZ6 Rotor 245MM is what the hohey big rotor bracket.
Stubbz63
I was runnin convertibars man, still am actually. You can't run the R6R/V triples the rake is closer and the wheel will rub on your radiator, been proven plenty of times, it'll bolt up and ride ok but it will rub. Rake is 24* on R6r/v and its 24.5 on R6S and 05 R6.
I pretty sure the R6s conventional forks have a 24 inch rake, the 05 is the only r6s body style with the 24.5
jesterchino
Are you running the iridium spark plugs or the regular resistor plugs? I read up on a stunt bums write up that you should use regular resistor type plugs as apposed to the iridium plugs that come Oem. I did that but sometimes the idle feels funky and I can't set my idle where I want it for a while when I first get to the lot. It either is too low or too damn high. I ride it around the lot a little while and rev the shit out of it and it eventually clears out. Feels like plugs are fouling or getting soaked in gas from the previous sesh. Once it clears out its tits. You think the gixxer coils will solve that? Never heard of the gixxer coil thing and would be dope if it solves my issue. Only happens here and there. Not a consistent problem. Almost feels like I should ride it around at high rpm's before I load the bike up in my van after every sesh to make sure plugs dry up a lil after all the slow idle stuff. Just guessing.....
I run the non irridium stock preferred plug, i cant remember if its the 9 or 10, its the same one they talked about on stuntbums "setting up a r6 article". The gsxr coil packs are longer than r6 stockers. I got the idea from Johnny Bravo a while back, the definatley work. I was running too rich and carbon fouling plugs, i could pull the plug and rub carbon off of it, so I had to adjust the CO2 settings per quadrant to match my 1st gen headers and R6r stock exhaust. You can do this through the speedo very easily.
I remember putting the gsxr coils in with new plugs and spending a couple hours at the spot riding and adjusting these settings until I finally got my bike running really well and the best of any settings I tried. This was 2 summers ago and it still runs as good as when I set it, same plugs, coils and everything. I went through 5 sets of plugs in a year on the stock coils before that.
R6 is a pain to get running really well sometimes, but the upside is its a very tuneable bike in stock form. With Tps and co2 adjustability, once you get those tuned to match your exhaust set up, and coils, and rectifier issue worked out you will have a very good running bike, that you wont have to mess with anymore unless u change exhaust set-ups
Threads: 21
GORBO
Eddies was an 09 R6S and he had R6V full front end and it rubbed also.
Stubbz63
The difference should in the triples though not the frame neck
Threads: 21
http://stuntride.com/vbstunt/archive...p/t-41127.html
It is, frames wouldnt be any different, the 03/04 and 06-09r6s has 24 for rake, 05 is 24.5 so really not sure one couldnt run the R6V forks and not have them rub if there same rake as the R6S triples. But from what everyone says use the 05 triples and you can use any forks you want.
Stubbz63
Yeah i feel ya. I really want to use r6v triples for the tighter rake. Does the wheel rub the actual rad or just the rad cage? Im also wondering if the r6v triples make for a even more narrow turning radius than the crappy radius it already has with 05 triples
Threads: 22
GORBO
more on teh adjustments with the TPS and CO2..... never heard of this but im currently running stock filter and airbox stuffed with wires and a newer r6 can for the muffler
I've never heard of a CO2 adjustment either.
