Im on the highway and a friend passes me. don't have high beams so while it's cruising I turn the key off and on to signal my buddy. Problem is when I go to switch the key back on nothing came on. No lights nothing. I pulled over checked the fuse on the solenoid. It was blown. Replaced it and have lights but it will not fire up. It's turning over tho, but the fuel pump isn't turning on neither is the throttle bodies when I switch the key off and on. Wtf is it? Fuel pump relay? CPU? Also I removed the fuel pump relay and jumped the wire, the fuel pump came on but still won't start. Also put a little gas in the injectors but still nothing. Some one help a brother out
Threads: 15
Check the ignition. There have been a bunch of threads recently on bad contacts on the wires in/ on the ignition itself.
Threads: 45
You leak all ur oil out again?
SQUINTS
na.. idk its acting up no oil issues this time. i fb messaged u about it. im taking it to corry tmrw at fantasy to check it out for me
Threads: 45
Nice I'm not allowed there during the week.
SQUINTS
Oh yea I did hear something like too robyn did mention weekends only. .. am I not supposed to go or something?
Sent from my SGH-M919 using Tapatalk 2
BUMP!
still having issues. fuel pump and injectors arent priming. all fuses are good, checked all connections and ignition im fucking BAFFLED
Threads: 15
demo4o1
BUMP!
Can you try someone else's ignition?
na i found out the issue. i fried my ecm. fml
