07 R6s
07 R6s
#31
why the hell you need a lift to put a cage on? that doesnt really make any sense. it can be done easily without a lift and many people do it im sure.
guess not, just brace the motor with a brick
idk if im just dumb but the threaded rod that goes through the swingarm pivot bolt is too big. goes in fine on the left side but not the right...
the rest is on for now.
you dont need to block up anything at all, just put one side on and the bolts in loosely then do the other side. even if you pulled all bolts out for cage mount your motor isnt movin there more bolts in it than what you need to remove and change.you have to drill the swingarm pivot bolt out to 3/8" so the rod will fit threw it.
after 2 hours of fighting with the swingarm pivot bolt and 2 broken drill bits, still couldnt get it. then came the carbine endmill, 4 seconds later, the cage is on
risers and handle bars ready.
clip ons back on so i can go for a ride, havent ridden in 2 weeks. who needs headlights, right?!
R6 is looking good man .. I wanted to try DB on my r6 as well
thanks dude. i cant wait to try DBs on this bike, just waiting on ss lines
good idea on the cage drillin, that was a pain in the ass the last quarter just would not fuckin cut.
it was work hardening. Next time, use low drill RPM and lots of force pushing the drill in. Some oil or WD40 to lube it will also help a lot.
i did all that shit for multiple hours, wd40, weezle piss, cobalt dewalt bits, wasted 2 of um in process, lot of force, slow rpm, fast rpm, recharged batteries many times over, tried everything, that last 1/8" just would not go threw. it finally did after i used some other bits and ate at it lil by lil but id deff do it different next time with a bit like he used.
