Threads: 14
Likes Received: 2 in 1 posts
Destroy it... Go in from the front and go underneath it and peel it up. It's just a thin piece of metal it folds up easy.
Careful not to gouge the swing arm otherwise you will have to take a die grinder and clean it up alittle.
Threads: 21
take a screwdriver and grind it sharp to help get under it to get started but like cel said make sure your not gouging the swingarm in the process. a little mark wont hurt just smooth it out before puttin new bearing back in.
Threads: 12
broham
what's the benefit of running those bearings in the neck? A
This new steel frame had no bearing races so I had to get some anyway, but all my bikes have the All Balls taper bearings...they are only like $38 and are angled roller bearings like on a car wheel instead of ball bearings. They are less likely to get loose, break, rock back and forth, etc. Just a better design
802bouffard
How did you get those needle bearing races out? I'm having a bitch of a time with that
I took a steel pipe/rod from the opposite side and caught the lip and knocked them out with a sledge hammer - it is a pain in the ass. And def use a socket to tap the new ones in like mentioned above.
Threads: 16
Indeed. tapered bearings in all my bikes since 05...
SIC Nate
Threads: 12
Didn't work on it as much yesterday, but I did get a little further and got it off the stands...
SIC Nate
Thank you sir!
Threads: 12
Threads: 21
lookin good nate, convertibars are so sick, cant wait to get mine all set and try um think there gonna be the cats ass
All that work and still gold forks??? Everything other than that looks amazing
Threads: 21
^^ he's gona throw some vinyl on um in a carbon look black i think he said.
