01-13-2013, 10:21 PM
you riding in Marion still? or somewhere around here?
04 636 stunt setup
01-14-2013, 12:59 PM
Well I found a spot in du quoin but its iffy.. I live in Pinckneyville again... Looking to move to the fair view heights/ o Fallon area this spring!! Riding in St. Louis is where's its at.. I'd rather haul my bike up there then try to ride around here. Cops just don't get it and there isn't really any good lots that are worth the trouble anyways
01-14-2013, 11:37 PM
one time I was at the lot I mentioned above and when I got there there was a smokey at the end of the street, so I asked him if he cared if I practiced riding there before unloading and he said it was alright until someone complains, and not to be caught riding it on the street (even tho my bikes legit)
01-14-2013, 11:40 PM
Hell yeah I'd ride there if I get a hauler
01-16-2013, 02:31 PM
Got my rear wheel yesterday cleaned it all up today hoping to get spacers and shock/linkage today or tomorrow. Still gotta order bearings and a tire so I still got awhile yet before I can actually do the swap.
01-16-2013, 03:05 PM
01-16-2013, 03:20 PM
01-16-2013, 03:45 PM
Your dead correct... It was a little un-centered in the hole but I didn't think it would hurt anything .... I could be wrong... I haven't rode it like that yet .. Does the stem bolt have to be flush in the hole of the clamp?
01-16-2013, 03:47 PM
That will cause damage eventually, as there is a lot of pressure put on that when you use the brakes or come down from a wheelie...I would make an adapter collar on a lathe if I was you.....Hohey does that for his triples so the same triple for 03/04 can be used on 05-08 by simply using or not using the collar
01-16-2013, 04:03 PM
Leave the ignition hole in the triple and mount a single reservoir in it with a T running to both master cylinders.
