09-20-2012, 03:15 AM
OK, hot off the mill! I've made 10 big rotor adapters for anyone that wants them. These will allow you to run '08-'10 (may be until current, I'm not sure) Hayabusa rotors on the back of your 636.
If you are running radial calipers, you should be able to use these with some spacers and possibly longer bolts because the rotor is mounted at the same offset from the center of the wheel as stock. I can make spacers for anyone that needs them and ship them with the adapter.
You have a choice of standard finish (pictured) or bead blasted for a more matte finish.
Rotor adapters are $100 shipped to the US. I can ship overseas, but it might cost extra. Send me a PM for payment info. The first two people to claim one on here get them for $75.
I'll also make you a set of aluminum spacers for $15
[image no longer available]
I should be able to ship them in the next day or two, I just need to pick up the hardware to bolt the busa rotor to the adapter. The adapter will be bolted to the hub using the stock hardware.
