How to start bike without lights plugged up
Hey guys first question.. im tryint to take my front ferrings and lights off when i hit the lot ... but my bike will not start if all the lights are not hooked up .. how do i bypass this (2002hondacbrf4i).
It's not the lights, it's the tip over sensor which is up front between them. You need to jump that. There should be a tutorial somewhere on here.
Connect the two outside wires together and leave the center white wire disconnected.
It's the little box with an up arrow on it.
Alright thank you guys imma give it a try... any tips on were the video is ...
You really don't need a video for this. There are 3 wires going to the tip over switch, connect the two outside wires [red and green I believe] and leave the middle one disconnected[white].
The tip over is the little black box attached to the upper with an arrow on it to show which way it is supposed to be mounted.
Sooo i cut the two wires put them together then cut the white one.... would this make my lights not come on when i hook them back up??
Like mentioned before, it's has nothing to do with your lights.
To be honest you might not want to do this, you haven't got it figured out in a week and it doesn't sound like you are understanding what people are telling you.
Originally Posted by old man roger
like mentioned before, it's has nothing to do with your lights.
:lol
if you cant figure that out then just open it up and put some super glue in it while its sitting level, let it dry, close it, tuck it away somewhere.
Originally Posted by deanknight636
This works too but if he cant figure out how to cut 3 wires then this might be like performing brain surgery
