hohey big rotor upgrade question
i have a hohey dual caliper bracket with a 954 right front brake caliper for my handbrake and also have the left front caliper just sitting my the shelf and my question is would i be able to rock both dual calipers with the stock rotor? (once i get the adapter bracket)
Ya it might not grab as much pad with a small stock rotor though but you should be fine
There isn't enough room on a stock rotor for both FR and FL calipers. On the big rotor kit there is room though
what do you mean not enough room??
You mean like this? This is the hohey kit and i have a stock sized rotor and it works fine and no pad trimming.
i have an 04 right now
Meant to say two FL's sorry about that
so if i run an FR and an FL ill be good with the stock rotor?
I believe u have to run trimmed pads without the big rotor
* just read up there that he needed no trimmed pads... but according to the site u have to trim pads without big rotor ... so im confused.. i have a big rotor kit and replacing it expensive so i wouldnt mind running a stock rotor.. just dont wanna have to buy trimmed pads...
yea thats kinda where im at i have a 954 dual caliper in my garage just laying there and i want to put it to use but want to know if itll fit without the big rotor
