08-22-2012, 06:38 AM
I was riding the fiddy the other day and I got pretty tired of burning my leg on the exhaust and standing all funny on the rear pegs. I saw a picture someone posted in another thread of their bike with an under tail exhaust that he had done, so I asked myself "... How hard could it be?"
Of course, here is is in it's stock form:
The first cut was... here ish. This is just about where the pipe will bend in around the subframe.
Next, I hacked the rest off of the silencer. Taking note of how much of the tube was protruding into the silencer.
I just happened to have this piece of 4130 leftover from my frame build. It's 1" OD and thinner wall than the frame, but it slipped right over the exhaust pipe so it was perfect!
Then I cut off the rest of the brackets, bead blasted, and welded on the "mount". I took one nut, and drilled out the threads, then stacked a normal nut on it and tacked them together, then welded them on to the silencer with the "hollow" nut on the bottom. This is just a ghetto way to stand off the threaded part to give some compliance with the mount screw...
