08-05-2012, 12:27 AM
I was searcing around the forum but havent seen a person with this problem....
Hopefully someone can give me a tip/advice on how to fix this issue...
Lately my water/oil pump has been leaking out of the weep hole, thus telling me a seal is failing, i purchased all the seals so that I could just fix the problem.. the problem lies in that one of these bastards will not come out!!!!!! It is stuck into the oil pump body... dont have a clue on how to get it out, spent the better part of an hour trying, and managed to damage the body in the process, so lesson learned on what not to do.....
Here is a link to a picture of the micro fiche to give you a visual of what im talking about. (I tried to embed it, but it kept coming out so small... sorry)
http://www.bikebandit.com/houseofmot...9315#sch293542
My problem is that the seal that is listed as part number #49073 will not come out of the oil pump body #16160, I need to remove it to replace the seal behind it..... but cannot for the life of me figure out how............................
As I said I damaged the body so I will have to use my spare motor to rob parts I guess...
or order a new one...
My question is, has anyone else ran into this, and if so, how the fuck did you get that seal out to service that seal and also the one behind it???
Hope OMR, or Johnny P or someone can offer some insite...
or order a new one...My question is, has anyone else ran into this, and if so, how the fuck did you get that seal out to service that seal and also the one behind it???
