Threads: 16
I want to know what ppl have ran and what you like that best these are all the MC setups i found to work for a HB. Poll being based off Perfomrance, Price, and feel.
1. Brembo front brake master cylinder 16x18 $330-$600
2. Brembo Ducati 748/916 clutch master cylinder 16x18 $180-$250
3. Nissin Honda 1000rr front brake master cylinder 19x18 $50-$125
4. Nissin kawasaki ZX-14 Radial clutch master 19mm $50-$125
5. Magura 190 Radial clutch/brake master cylinder 16mm $350-$500
6. Magura 195 Radial clutch/brake master cylinder 16mm $250-$350
7. Nissin Radial clutch master cylinder 19mm $170-$220
8. Yamaha R1/R6 Brembo front brake master cylinder 19x18 $50-$230
9. Brembo clutch master cylinder 16x18 rcs $350-$500
What caliper are you going to run the master with?
Depending on the caliper piston size a 16mm can have a good feel or it will be hard as a rock...
Threads: 66
Missing 13mm Magura, a lot of people run that...
Threads: 45
+1.... i still vote for 16x18. when ran to 4 piston its got much more consistent feel than 13mm IMO
the brembo vs magura is more personal preferance, but ive used the a few newer R1 radial masters, brembo 16x18, magura 13mm 195 master, BUT none of them have compared to the performance and feel of my Magura 13mm 190 BILLET master! that thing is Pimp!!!
and the combo of a Billet Magura and RSC is butter
Threads: 16
im doing a 4 piston with stock
Threads: 16
I thought the 13mm is only for 2 piston not a 4 piston
r6 brembo. 100bucks, done...
Threads: 16
are the 19mm radial clutch to big of a bore size or what, i dont see why to spend $350 bucks when you could get something cheapier that performes just as good or better. But i could be wrong but if you ran any other combo please comment on it.
I could be mistaken, but aren't #8, the r6/r1 brembo's 16mm?
