07-22-2012, 09:05 PM
these fit banana seat f4i subframes too?
Righteous sub-cage!!! R s c!!!
07-23-2012, 03:00 AM
I think so. Lets ask OMR.......hey Rog......will it fit?
![]() Thanks in advance, buddy!
07-23-2012, 03:03 AM
coughcough929rearsetscouphcouph
I got something in my throat... Sorry....
07-23-2012, 02:10 PM
The banana seat rear peg brackets fit in between two tabs on the subframe and are pinched when the bolts are tightened, the single seat peg brackets fit outside of the mounting tabs on the subframe. You would need to space the mounting plate on the rsc subcage out far enough so it could bolt to the outside of the banana seat subframe, then place spacers where the stock peg brackets used to go. This way you could bolt the subcage on just as if you were bolting it to a Slightly single seat style subframe.
07-23-2012, 02:15 PM
I almost forgot, the mounting holes are a little closer together.
That could be taken care of by opening the holes a little bit.
07-23-2012, 02:16 PM
Ahhhhhhh.......Roger pullin through w/ the important info!! Thanks buddy!
![]() Now....with that answer in mind.....I'd have to get one in the shop to get measurements, and make sure everything lined up correctly. Only thing is.......I don't know of any bannans seat models in my area. Now...if someone has an extra bannana subframe they can send me....I may be able to work off that.
07-23-2012, 02:25 PM
Not alot of room between the tire and the subframe on the single seat style subframe, if I were you I would want to have the whole bike there to make sure every thing cleared.
07-23-2012, 02:36 PM
07-23-2012, 02:44 PM
Sounds Like WHEELIE has the Case of the Mundays...
07-23-2012, 11:34 PM
appreciate the info guys thanks
