^^^ what he said. Atown for ftw
Threads: 9
atown over sick innovations. same cage, just think the rear mounting point on the atown is better to the subframe...
i heard the 905 getting good reviews. it used to be a garbage cage but after the redesign a lot of people are talking good
Threads: 27
Originally Posted by zprt00
Godfuckingdamnit  So do you recommend it, or did the bike explode into thousand pieces and you tumbled down the road and died? I'm curious because I have a clapped out 905 on my f4i.
I highly recomend it. Only thing that broke was my scapula my bike is still ridable, all i need is new sliders.
.... did you seriously just recommend a 905cage.??
Threads: 35
Likes Received: 1 in 1 posts
Umm what?
Threads: 9
Originally Posted by MiNi GuineA
Umm what?
sick and atown are the same cages. sick mounts to the rear mount, atown mounts to lower subframe bolt. ive busted rear mounts wit the sick cage, therefore i like the atowns mount to the subframe bolt better
Threads: 35
again... what??
Neither of thoes cages have anything to do with the lower subframe bolt
they do both mount to the swing arm pivot?
Threads: 13
again... what??
Neither of thoes cages have anything to do with the lower subframe bolt  they do both mount to the swing arm pivot?
sick mounts to a motormount bolt, atown mounts where the lower subframe bolts would be.
Threads: 9
again... what??
dude u ok? lol
the atown mounts to the lower subframe bolt on the f4i
sick innovations goes to the rear mount
