been having problems with the idle , as soon i hit the brake or i slow it down it gets weak and it starts to sputter or it tries to die on me
. any tips of what could be the issue?? thanks.
Threads: 23
When is the last time you put a set of plugs in it?
Threads: 43
Likes Received: 1 in 1 posts
Put an air filter back in it.. lol.
Threads: 23
There are so many possibilities it's hard to diagnose over the net.
Common causes I have seen on this forum are
Water in the gas
Plugs
Clogged pump
Corroded electrical connections
Bad harness
Bad battery
Bad tps
Loose throttle bodies
Throttle bodies out of sync
Bad coils
Hell the list goes on and on.
Threads: 14
old man roger
Water in the gas
Plugs
Clogged pump
Bad harness
Bad battery
Bad tps
Bad coils
Loose negitive battery cable lol....
old man roger
Water in the gas
Plugs
Clogged pump
Bad harness
Bad battery
Bad tps
Bad coils
navajowalks
Thanks , I will give it a try
Threads: 23
I've even had a fan motor going bad cause the bike to run shitty.
old man roger
Now that mention that my fan seems to run weak
Threads: 23
E.T.
It may be pulling alot of amps.
