If u want some inspiration .. I look at , Jesse Toler , rowdy (which will prolly be in this post later ) , gage , Mitch Adams ... Jesse out rolls all
coolierr
Pilot front tire is a must! . Just keep going at it... Take ur time and learn stoppiez . Cause going over will suck .. U will eventually hit that balance point , to we're u really don't need to be on the breaks tht much . I am hitting the Bp on and off.. But just keep going at it
Pilot power is what i run. I run about 20-25 psi depending on the temp outside.
coolierr
you havent seen bforeman do em yet. he's sick. he was sponsered at like 14
Thanks for all your help guys, I'll post up a video asap
I can only do 5f rolling not bp but Sometime, my front tire keep sliding to the other side when i try to grap the front break..does any1 know wat cause this?
Zx10r_baowao
ur front tire slides to one side? do u mean its like locking of and wanting to slide out? if so ur locking up the wheel and thats what is causing it to slide out...too much brake
RockintheR6
Yeah, sometime i try to grab the break harder to bring it higher, the front wheel just slide to the right side actually
Zx10r_baowao
ya if u do it hard like that you will either lock the front wheel up and it will slide out or it will lock the front wheel and you will flip the bike on top of you. both are bad lol. nice gentle pressure...more brake to bring it higher, less brake to bring it lower
