zx14 front rotors/r6 calipers
ok so i just need zx14 front rotors to put this front end on...who's got em?
bump...still need these rotors
the R6 calipers are spaced correctly when using ZX14 rotors? what kawi forks are you using?
08 forks and yea r6 monoblock calipers will bolt right on.....they are made for 310mm, zx14 rotor (310mm) works perfect for em...and they bolt right onto my 03 wheel.
Originally Posted by KawaSquidly
hell yeah, nice
what size are the newer zx10 and zx6r rotors?
not sure what you mean by newer, but the 08 zx6 (the forks i have) are 300mm and 08 zx10 is 310mm, however, it won't bolt straight on to my 03 wheel. That's why i'm goin with the zx14 rotor cuz it's a direct bolt on to my wheel and the r6 monoblock calipers are for 310mm. Hope that answers ur question buddy....not sure if you meant newer, like the yr that i have or newer like 2012
u got it, i have an 04 636 with 05-06 forks and wheels, 06-07 zx10 rotors, and wanted to put the 08 r6 monoblocks on it, so does this mean i need a 10mm spacer to avoid pad overlap??
that i'm not sure of bud...i do know that if you go with 1000rr calipers, you need a 5mm spacer cuz the RR rotors are 320mm, if that helps at all...lol
i still need those zx14 rotors guys...and the r6 monoblock calipers that i was gonna get, fell thru...so i need these as well
