So i just bought a 03 636 I've always been on Gsxr's. But everytime i wheelie i hear a cracking noise that sounds like my chain is skipping a tooth but that's not possible because i just got a new chain and sprocket. I've heard that you have to cut the gears in order to fix this problem but im not sure. Does anyone have any tips or suggestions for me. Im totally lost
Threads: 63
Diffrent size sprockets or chain that dont match. Sounds like bent sprocket teeth.....didu replace the front as well?
ya i replaced both including chain and sprocket
Threads: 8
Its likely coming from the crack in your frame.
cut the gears??? what the hell does that mean?
Threads: 8
SPAGS
Pulling the gears out of the transmission and back cutting the the contact areas so the gears lock in better to prevent "slipping out", because no one likes it when that happens
