12-08-2011, 12:53 PM
haha damn you have read my mind actually sir... below is my mockup as well as the hot wheels toy I found last week at wallgreens. (of course i'm doing it in neon orange instead of red)
My Motovan Build/Project (WARNING LOTS OF PICS)
12-08-2011, 12:55 PM
That's sick!!
12-08-2011, 01:27 PM
Awesome!
12-08-2011, 02:23 PM
just more info and stuff i'll post the final pics of the interior today also...
This was my first solution to all the holes in the floor ... (forgot to post this) just picked up these plastic pops at advance auto parts for bunch of them i think it cost me 10 bucks ... drilled the holes out (they were too small for the pops originally) then I siliconed the pop stuffed it in and then siliconed the top to ensure water woudlnt come through... ![]() This solution probably would have been fine but aaron twite offered to weld them for me so I ended up taking them out and having aaron weld the holes. (didnt take photo of this ... but welding is a better solution if you can do it) The foam insulation on the walls and ceiling... (home depot) ![]() Here is the silver insulation I bought from lowes... (they did not have it at home depot) ![]() OSB... I ended up buying hte kind with radiant shield (reflective foil on one side) for about 7 bucks each. But this gives you an idea... ![]() The grey porch/deck paint for water proofing (from walmart) used this on the osb... the pegboard.. the ceiling in the garage.... and my futon... ![]() The masonite or hard display board i used for the ceiling... bottom of walls... wall on the rv side... and some covering on my futon. ![]() Pegboard (walls in garage) and will be using for back door covers.
12-08-2011, 02:47 PM
12-08-2011, 03:27 PM
Futon Version #3:
Animated gif of images above: http://sevom.com/nacstuff/MOTOVAN/VanFuton.gif ![]() This is where I'm at right now... so I'm all caught up on the pics.... I have ordered a few things for it and will be updating this weekend... but my design for the futon is to have a 4 inch memory foam top that is black fabric covered that holds onto my carpet with velcro. The design is in my head of how it will all go together with the opening tops and lids but you will see.
12-08-2011, 04:09 PM
12-09-2011, 07:30 AM
subsc
12-09-2011, 10:28 AM
is that just indoor/outdoor carpet you lined the masonite with?
12-12-2011, 07:39 PM
Setup is sick!
i just picked up a $500 Astro(95 awd). although i wanted an express, i couldnt pass up the astro from a friend. passenger, im in the process of turning into my hauler. but damn, i really want an express now, after seeing what you've done. |
