12-03-2011, 02:48 AM
Ive got a little girl on the way, should be here by jan. 26th and im entertaining the idea of selling my dual wheeled motorized transporting device.. Its a 04 zx6rr, salvaged title (was registered in CA when I bought it so was inspected and reregistered) I have the certificate of title for it that says 4890 miles so im sure it has under 6 thousand, easy. Ideally would like to get $3500 for it, but we all know its not an ideal world so make offers. Im located in Las Vegas, might be willing to drive depending on how far and of course you meet me.
Cant remember gearing im high, ill say 54 and down one up front.
What needs fixed/replaced is rearsets (currently welded and work fine but obviously should be replaced) passenger pegs, radiator is patched and is fine except for one small leak that I havent found. Theres a small chip in left motor mount from previous cage but its held up fine since so not a big deal, will send pics of it if wanted. Has front and hb reservoir lines hooked up but not the right tubing it bleeds through. Dumb.
Added parts are as follows:
Shorty 12 bar homemade but diesel
SI cage
Magura 13mm hb
RSC bling shorty
New motionpro clutch cable
07-08 silver forks, front wheel, rotors and front master
Fullthrottle junction style hb, im not baller status lol
OMR subcage
Included:
Oil and filter
Coolant
Brake fluid
Cant remember what else..
I dont have the rear hugger mounted but I have it, the old 04 front fender as well. I also have the 04 front wheel and rotors the wheel is gold and bent but is rideable if needed. Hole cut in rear seat and stitched by me, probably wont hold up too well but it looks clean for now haha. Paintjob is rattlecan black metallic, not the best but looks good. Exhaust is stock cut real short and sounds absolutely lovely, its painted with high temp black paint.
Has two small foglights up front and a integrated taillight just havent figured out how to get the blinkers working, comes with the wiring and universal horn/blinker/headlight switch. Has the kleen air mod, relocated the ignition by the subframe, and flipped top triple clamp. Thats all I can think of for now ill post more if I remember, if you have any questions pm me. Ill post pics in a min..
SI cage
Magura 13mm hb
RSC bling shorty
OMR subcage
Included:
Oil and filter
Coolant
Brake fluid
