Threads: 17
\r\n \r\n \r\n \r\n \r\n Originally Posted by ReCkLeSsRyAn\r\n  \r\n \r\n   I appreciate it man!!! Pay pal? \r\n \r\n | \r\n
let me check my garage first lol i have class till about 2 then ill run to my garage and take a peek and see what is all in there and then ill shoot you a pm
\r\n \r\n \r\n \r\n \r\n Originally Posted by ReCkLeSsRyAn\r\n  \r\n \r\n Price? \r\n \r\n | \r\n
$35 shipped\r\n
Threads: 24
\r\n \r\n dont forget your gunna need a bad set of forks and both upper and lower triples so that you can mount your handle bars, or at least some tubing thats the same size as the forks\r\n
Threads: 27
\r\n \r\n \r\n \r\n \r\n Originally Posted by maverickxp\r\n  \r\n \r\n dont forget your gunna need a bad set of forks and both upper and lower triples so that you can mount your handle bars, or at least some tubing thats the same size as the forks \r\n \r\n | \r\n
I got a set of f4i forks. One fork is good and looks straight. Other fork is missing the outer silver casing but all the internals are there. Get a casing and some oil and ur all set. Id do 50+shipping.\r\n
Threads: 45
\r\n \r\n Just mount up db bars and problem solved\r\n
Threads: 43
Likes Received: 1 in 1 posts
\r\n \r\n \r\n \r\n \r\n Originally Posted by SQUINTS\r\n  \r\n \r\n Just mount up db bars and problem solved \r\n \r\n | \r\n
ding ding ding\r\n
Threads: 45
\r\n \r\n \r\n \r\n \r\n Originally Posted by StuntBikeJake\r\n  \r\n \r\n ding ding ding \r\n \r\n | \r\n
Win\r\n
Threads: 24
still gunna need upper and lower triples though unless you bolt db bars to your frame\r\n
Threads: 45
\r\n \r\n \r\n \r\n \r\n Originally Posted by maverickxp\r\n  \r\n \r\n still gunna need upper and lower triples though unless you bolt db bars to your frame \r\n \r\n | \r\n
Yep. Triples so u can still "steer" lol
Threads: 31
Got the frame motor swing arm and rim for cheap always wanted to ride a unicycle f4i but never wanted to do it To my own bike
trying to build this on the cheap cheap since it's gunna get destroyed
Needs:
Air box
Shock
Rubber boots that attach the tbodies to the motor
Header
Electronics
And I'm sure there's for I'm missing but I add later
