12-29-2009, 03:52 PM
haha ıt will be ok
Fiddy Repair and Maintenance.
haha ıt will be ok
01-04-2010, 02:34 PM
09-05-2011, 06:24 PM
anyone know how to straight out the front wheel? i tried loosening everything, then straightening out the wheel, then tighten it but it keeps going back to being crooked.
09-05-2011, 08:33 PM
I always butt it up against something and turn the bars. Or, hold the wheel between my feet and turn the bars. Stop crashing and it'll stay straight.
Also, this thread is mega old.
09-05-2011, 09:20 PM
09-05-2011, 10:58 PM
Something has spun inside one of the forks , lower busshing is worn and sloppy , the upper retainer is worn , or the spring has shifted inside . Go watch the suspension install in tech support on 50stunt . it will show you everything that is inside your fork tubes .
09-06-2011, 12:10 AM
12-19-2011, 05:08 PM
Can anybody help me,I did an endo on my crf 70 and my knee hit the throttle cable.
The idle shot way up,i moved the cable back and forth to solve the problem but every time i move my handlebars to the right my throttle shoots up and when i go to the left it goes down? any advice would help. Im sure its something simple, but any advice would be appreciated.Thanks
12-22-2011, 09:50 AM
Could possibly be the way you've routed the throttle cable from the throttle to the carb. When u turn right it's pulling on the cable. My bike does the same but only very slight and i need to turn the bars quite alot to the right
