Ok my front wheel is rubbing my throttle side fork tube so I pulled them apart and holding the fork legs next to each other one was definitely longer (the spring) so I pulled everything apart put in the delrin bushings and unscrewed the spring ends and than springs were same length side by side. Put it all back together and they were same length. Reason why fork tube was twisted is because they had top spring deal tab180 from where it was supposed to be. I put it all back together and tubes measured same length. Bolted axle in with wheel than it did same thing tire rubs throttle side rubber dust cover. Wtf is going on
Slightly bent fork legs could be your issue
Maybe you need to change wheel bearings
hub could be warped/ bent on wheel
spring could be worn out
should check the spring rate
Just the stuff off the top of my head GL
Ok wouldn't think legs bent this thing is so mint looks like its never been ridden. Sri g rate could be diff but weight isn't on it.I have it on a stand and it's still wrong. I just have the one stock spacer and the drum in the other side. Wouldn't think its spacing because the whole tire isn't moved over just cocked at an angle
