Threads: 15
0
\r\n \r\n got something brewing in the office. wrap should be finished in like another week.
\n
\nquestion, is high temp rattle can paint bad on the motor?\r\n
0
\r\n \r\n On my engine, I used duplicolor 500f engine paint.
\r\nI also primed my bottom end with regular old duplicolor self etching primer, however its not rated for high heat.. I heard people had no problems running that primer on water cooled motors, so I figure it \'might\' hold up on this one, but air cooled motors DO run a LOT hotter then water cooled (water cooled will typically run at 180 and max around 230 ish) air cooled will run regularly in the 200-250 range and can break 300f easily
\r\nSo far no issues with mine, it\'s holding up great.
\r\nI didn\'t use any primer however on my cylinder or head, as I was worried it would bubble off...\r\n
Threads: 15
0
\r\n \r\n I have just a 50cc motor. Got my TTR and crf I\'m thinking about painting\r\n
Threads: 15
0
\r\n \r\n So should I use a primer first? Or does it matter with rattle cans?\r\n
0
\r\n \r\n Engine paint is thick... Primer isn\'t nessecery\r\n
0
\r\n \r\n two questions the couple bikes with round bars what did u use to make them.
\n
\nthe bike with the hart and huntington rockstar graphics where did you get them\r\n
