what could have caused this?
#51
Quote Originally Posted by adichino
i so fuckin regret now i didnt take a picture of that tshirt!
tomorrow i will open the engine to see what went wrong .. pretty excited coz it's my first time
omr, what electric valve are you talkin about ?
The 636 is vacuum operated, the f4i is electric.
I think it's called the air switch valve on a 636, it's the plastic valve on top of your valve cover.
Air injection control valve on an F4I
if what you are talking about is the stock part which most people use to do the clean air mod instead of a T tube, then i cut the wire, its no longer attached to the main harness
anyway, i stripped down the engine today, found out that 2-3 disks from the clutch are broken and rod #3 had broken and had grenaded into the engine case as most you guys assumed
i didnt manage to remove the flywheel and clutch as i dont have a rotor puller and a clutch center holder
is there any way to remove those without the tools or i need to buy the tools?
Thats exatly the part I was talking about but I was actually replying to stunna dales question, I think your problem was probably caused by the guy that left the t-shirt in there.
you didn't see any large amounts of oil in any of the cylinders right?
the cylinders were clean
its funny coz i bought this bike in 2009, somewhere in august and i opened the engine last month and saw the tshirt ... the engine has run perfectly during all this time
what a rod cannot break if you revlimit that shit 4-5 minutes?
whats your input on those two tools to remove the flywheel and clutch ?
See knock on wood, ran fine til you took out the magic shirt. Ya fucked yourself man
Quote Originally Posted by PeRkz
true that hahah
i managed today to remove the clutch with an air pistol and the flywheel with a ghetto puller and a torch, split the cases and took it to the welder .. tomorrow i will see his magic cant wait
You're gonna fix that motor? You could probably buy a used one cheaper
yea i will try if not i will buy another f4i
the germans are crazy when it comes to engine prices ... one f4/f4i is at least 600 eur
i paid like 100 eur for the rods, crankshaft and the engine case, the case is not good but probably i will turn it into a small coffee table
the welding is 100 eur tops, so im good with 200 eur, if everything goes fine of course
so today i got the case from the welder, i hope it will hold
so then i went to the garage, cleaned the case and put in the pistons rods and shaft
and assumed that top dead center is when piston 1 and 4 are at the top of the cylinder - that was to me the only way for the rods to be straight
i tighten the the rods to 25nm as written in book
i then tried to rotate the shaft but i couldnt
could this be because of the new set of rods&pistons which might not be aligned to the cylinder?
or i did some stupid shit ...
