what could have caused this?
#41
Maybe it was time for the motor to go to rest
Quote Originally Posted by B-rup
Its cuz you painted your f4i Kawi green......bike started acting like one
lol
funny story, looks like something went wrong during rebuild.
a few revlim's doesnt hurt an engine!
Judging by the hole in the block I would assume a bent connecting rod at the very least, probably a broken rod though.
Yup I agree. If anything broke it would be a rod, takes such a heavy tensile load. If there aluminum rods they would have grenaded which would explain the hole.
Looks like some one didn't do the clean air mod.
''If'' you have oil in your air box then you probably pumped oil from your crankcase vent tube into your cylinder.
This will cause the motor to hydro lock ..Oil doesn't compress so the connecting rod did.
Another reason could be that you blew a head gasket and filled a cylinder with coolant, coolant doesn't compress so the connecting rod did.
omr have u ever herd of the f4i pumping oil in the cylinders cuz of too much pressure in the case due to the clean air mod?! this f4i i just picked up was doin it till i took the clean air mod off. my guess is that it was building up too much pressure in the case and pushing oil past the valve seals cuz once i removed the clean air mod it quit! my f4i b4 this one i never did the clean air mod and i had 31000 miles on that motor and it never did that... parked it on the tail numerous times and i never had a prob with oil in the airbox...??? let me kno if this sounds legit cuz thats where im at with this f4i
Quote Originally Posted by GORBO
sounds like somebody put in a order to stuntex for a oil pick up and t-shirt then got confused..
not everybody is goin to be smart enuff to tell the difference!
Just smash the hole with a big hammer and look inside
i second this! relieve a lil stress as u r doin it! b creative with it... sawzalls work great also!
that was some wacky shit
Quote Originally Posted by stunna dale
Sounds to me like the clean air mod was done incorrectly, when done correctly it will actually create a vacuum in the crankcase, not pressure.
The f4i wont normally have an issue when on the tail, the crankcase vent on the f4i is on the top left.
The problem would happen when the bike is lying on it's left side or if it rolls over the cage and the tank and tail are touching the ground, or obviously if it's upside down.
This is a guess but it sounds like maybe some one didn't unplug the electric valve when they did the clean air mod, the valve needs to be unplugged to stay open or the system will build pressure.
i so fuckin regret now i didnt take a picture of that tshirt!
tomorrow i will open the engine to see what went wrong .. pretty excited coz it's my first time
omr, what electric valve are you talkin about ?
