09-13-2010, 01:18 AM
TIP TOP READY TO ROCK!
current orders out tomorrow, got a few left. take a real close look at edub's x-games pic. his skill, my bracket and a gxsr 1k caliper.
+BENEFITS+
-replaces the oem chain adjustment block.
-moves with your wheel and axle when you adjust chain.
-HAVING A DEDICATED 4 PISTON RADIAL CALIPER!
-cnc'd aluminum block.
-can use almost any front radial brake rotor, LEFT or RIGHT side.
-easy tire changes. push axle out and slide bracket/caliper off rotor out of swingarm, then axle completely out and wheel off. wheel on: put wheel up and axle through to other side of swingarm, slide bracket/caliper on rotor and into swingarm, push axle through bracket, tighten castle nut and adjust chain tensioner.
-all brackets are mounted and tested prior to shipping.
-can be fitted to the big rotor!!!
will have other models made soon for 05+ ninja, 04+ gsxr as well in the coming weeks.
also will be milling big rotor adapters for the oem 03/04 636 calipers
+BENEFITS+
