04-04-2013, 10:44 AM
sounds like your correct there. there should be a compression on bottom and rebound on top and spring can be adjusted also, theres a min and max the length of that spring should be set to.
Suspention set ups
04-04-2013, 11:30 AM
Yessir, need different springs if you max it out either way trying to achieve the correct sag as far as I know
04-04-2013, 12:23 PM
never bothered with sag on any bike ive had. i just play with settings till i find the area i want my bike to be at and run it.
« Next Oldest | Next Newest »
