Less than 1 minute ago
Honda 600RR pics
\r\n \r\n Yea!!!! Get on xbox damnit\r\n
\r\n \r\n Coming together nicely!\r\n
\r\n \r\n Update\r\n
\r\n \r\n kirny, get my parts back from powder tomorrow homie, ill send u some pics when i pick it up......\r\n
![]() \r\nHere is a sneak peak\r\n
\r\n \r\n wow
that looks like shit imo.\r\n
\r\n \r\n ^^^^ u must not know kirny........looks good man. Get crazy white plastic again like yhe durty 6\r\n
03-06-2012, 05:15 PM
Alright guys when I got this bike it was a hot mess.....airfelt crumbled in my hands, airbox was just sitting on top of the throttle bodies no clamps at all, handbrake caliper only had two threads on one of its mounting bolts holding it on, fork seals trashed, 532 60t rear sprocket and 14t front with rusted out chain, kill switch was broke and would randomly shut off, rectifier went out on my ride and killed the battery too, no kleen air mod, did not bypass the neutral switch or whatever u wanna call or (enables you to start in gear), throttle cables clutch cables u name it it was bount up because of the way he routed in them, tank has a 1/4 inch lip made out of bondo that I already broke and used griptape for his tank pad (clearly he didn't do much in the tank), radiator mounts broke (ziptied on)........it looks decent in these pics but believe me doesn't look this good in person......I have slowly changed all of this and in the process of changing the colors and doing some other cosmetics........I will post pics as I get parts and change colors and will also have a full part list of everything I have used........stay tuned!!!!!!!!
« Next Oldest | Next Newest »
. And can\'t get the 6 piston bleed\r\n
