sickinnovations or impaktech
#31
Why do no companies make cages that are separate for each side? Instead of connecting
Quote Originally Posted by nags
because it is easier to make a cross bar connecting each side then it is to make a cage that has enough mounting points to be strong ..
on most bikes you would need to us the lower motor mount for a third mounting point and that is more work then just making a cross bar..
The Impaktech KrazyKyle cage would be so sick if each side was seperate
less stress on the cage if it connects to the other side as well because your using the strength of the 2 sides together.
tyger shark was ok but it is not a cage for learnin. its only good for guys who can ride wit out crashin much since its only got two point that it bolts up to an doesnt bolt under the bike like most cages your prone to breakin a bolt off in the frame. i liked it at first till i started crashin an breakin bolts its a bitch if it connected underneath it might be the best cage out there. but impaktech is the shit imo good prices an built from super man tank stell lol
Quote Originally Posted by C.S. GIXXER
i think tyger shark offers a cage that has a cross bar
y would you not want the cage to connect to each side at the bottom??
mine has the cross bar.
the cage absorbs the shock from one part to another and bounces back, when its connected
Sick innovations has always taken care of me and my team.
