12-24-2013, 01:23 AM
Everyone is knocking this but it actually pretty good if you have never done fork seals... good post with pics. I use pvc pipe cut in half as a slide seal drive, works great and is like $1... spring compression tool can be made out of 2 1/2 inch steel tubing drilled and tapped for all thread. Costs about $5 from you local metal shop...
Sent from my SM-N900P using Tapatalk
