His Stock kawi rear caliper mounting bracket looks like its a little tweaked. I took it off and could see where the rotor bolt is hitting the stock mount bracket and it was wearing a groove into it. It was deep but you could deffinetly see it where it was hitting. Rottating the wheel you could see a small gap form now n then when the rotor turned in the pads, making me believe the rotor is a little warped causing that hard spot when spinning the rear wheel. Would be better off buying a know to be good/undamged stock mount bracket and ill put it on and if it still hits ill get it machined down to fit. Some brackets need to be trimmed now n then. Tim had to grind his DCB from FTinc down a little becuase where the caliper mounted wore a groove right into the rear wheel and it was mounted exactly to the instructions.
I was in his bike all over the place, i couldnt find a single thing wrong with it, bike was running like a raped ape. Im willing to bet that its the caliper rubbing on the rotor, causing it to drag and make the bike feel boggy and then when the throttle hits he gets all the power. And itll only get worse the more it drags causing it to heat up and expand.
i thought his rotor was brand new. i know the caliper was an issue in that one spot cuz he has no footbrake or not for shit anyways which is a given. I'm wondering if he has a bit of powdercoat on the rim mating surface to the rotor and thats causing the rotor to appear warped. remember how my front brakes were and there mint now that i found that little piece of powder under one part of the rotor. i'd almost be willin to bet that might be a culprit.
Threads: 22
Threads: 45
did you powdercoat your rotor or NDC bracket?
Threads: 22
SQUINTS
no just the wheel.
Threads: 14
ajbsays
no just the wheel.
Did the powder coater tape off the surface that the rotor sits flush against, on the wheel?
Threads: 22
Righteous 1
yes he did, but maybe not enough because this galfer rotor is a beast lol! but he deff taped off all mounting spots.
he taped off mine to but guess what.... Check it cuz theres noway your rotor should be that warped that fast unless it was flat out draggin like hardcore
With the bike lifted up, he spun the wheel as i watched the pads and rotor. Theres a portion of rotor that doesnt contact the pad leaving a small gap. If he brings the bike back ill take a dial run out gauge and ill see if its still true or not. AJ if ya want bring that bike over next week and leave it for a couple days and ill check all that shit out and measure everything for ya.
Threads: 22
Ok Kyd, yea man I ordered a new caliper bracket, and if I gotta order a new rotor I will. Just want her to be 100% and if it is warped then it was dragging and that's prob why it is so jerky
