10-01-2012, 11:23 PM
I still can't believe this* SHIT
RSC Adjustables
10-01-2012, 11:43 PM
hahaha congrats fellas!!! was there any logic or exp behind the guess? awesome thread man!
10-01-2012, 11:54 PM
Send josh a free bottle of nerium for being such a butthole in the past blox....a nice gesture for another. Age defying anti wrinkle cream ftw.
10-02-2012, 12:11 AM
A few of you may have heard about these. Those that haven't.....let me introduce you to the RSC Adjustables!
The RSC Adjustable handlebar setup has been designed with durability and long life, being my main goals. There are no threaded aluminum holes. Individual nut pockets are machined precisely behind each bolt hole, providing stainless on stainless threads for all clamping areas. All threads have been hit w/ a small amount of Anti-Sieze, to prevent galling. The upper clamps are seperate from the riser bars. Riser bars can be swapped out w/ any 7/8" bar stock, allowing for a bent riser to be changed out...on the spot. The standard finish is the tumbled silver finish. Bars are also tumbled to match. Black anodized clamps will also be an option, soon. Custom colors, and full anodizing...including bars....available on request w/ an expected wait time. As most know, adjustable handlebars can require rerouting of cables and wires. Once in a while, that prefered position may require a custom cable or addition to a wiring harness.The RSC Adjustables carry the same Lifetime Warranty all billet machined RSC products carry. Hardware is not covered, but if you crash.....and damage your billet machined parts, to the point they no longer function properly.....I will replace them w/ fully functional pieces. ![]() Pricing: Tumbled silver finish 50mm/51mm: $275 plus shipping($10 US, $20 international) Anodized clamps w/ silver bars, any color: $310 W/ anodized bars, also: $325 I may do 43mm, if there is any interest....... Now, for the GIVEAWAY!! ![]() ![]() Pretty simple, really. Everyone gets one guess....... I start w/ 4 blocks of aluminum, when making a set of bars. Your first guess(to yourself) must be how much those blocks weigh. Then, you must guess how much of that wieght gets machined out....throughout the machining process. THE GUESS YOU POST, IS THE AMOUNT OF WIEGHT THAT YOU THINK IS MACHINED OFF THE 4 BLOCKS....TO COMPLETE THE MACHINING PROCESS. As I said..... 1 GUESS EACH!! Winner receives a set of bars!! Contest ends, and the winner will be anounced....on October 1st! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() [/QUOTE]
10-02-2012, 08:20 AM
congrats! I was way off I was using numbers and stuf! .lol
10-04-2012, 06:33 PM
All I can say is WoW, just got my clipons from Cali to Stl in 2days just the same as it took for my RSC
lever...The shipping is so fast it should be illegal!!!!..lol It was awesome of Josh to even consider a runner up. Without the discount it woulda took some time to scrape change for them. The quality of these bars is all there plus some. Cant wait to get them on & snap some pics!! Thanks again Josh & look forward to doing more business with you. Dont you have an exhaust out also ? ...LolI also noticed that some of u have them ontop of tripple & some below. Is it preference?
10-04-2012, 06:45 PM
good to know. he is making mine sometime soon for my 600rr front end.
been wondering how i am going to run these full my full uncut upper......... so many positions im sure i can figure it out.
10-04-2012, 06:48 PM
i just ordered a set of these, i want them to be like darwin bars/ dirtbike bars. for you that rock them already how do you like???
10-04-2012, 07:15 PM
![]() RSC Fo Life.
10-04-2012, 07:29 PM
sickness. Way better than my SI adjustable I had before. SI you bend your riser its over, these you can bang around and just replace individual pieces.
Which is awesome because I know my bike hits the ground wrong im not going to spend 300$ on new stuff. Also the multipul bolts I like because they all go into thread lock washers so you know your bars arn't going to come loose. Josh actually jinxed me with this right before I got these new ones from him. I bent my SI riser that day. Guess it was fate. Also you can't say they don't awesome
« Next Oldest | Next Newest »
