F4i ignition toggle switch HOW TO
#21
ok makes me feel a little better lol
Figured out why it stayed running, fan acts as a generator, no big deal.
how did you figure that out?
Unplugged fan from radiator
trimmed switch knob down to reduce chance of kicking, once the switch is turned on it is behind the tank by the round hole on the tank so no chance to hit it, thanks congo for the diagram
if your bikes are staying running after the key if off you have a bad ground , i found this out doing the duel fan mod
Whichever ground might that be cause mine doesn't do it all the time just sometimes
mine does it everytime, my fan is grounded out to come out when i flip the igntion though, i like it that way.
as is mine but how do you check for bad grounds?
Radio shack no longer has the 30amp toggles without an illumination light.
What happens if i use a 25amp switch rather then 30? Is that ok? Or should I use a 40 or 50 amp??
