Forstunt.pl - quality stunt parts from Poland
#21
Quote Originally Posted by ReCkLeSsRyAn
the r6 bracket on your site that holds 9 pistons u have those in stock?? what is it in U.S dollars?
R6 HB bracket is not in stock and it will take arround 10 days to make it.
So i got, my r6 subframe a few days ago and the pipes are lined a bit off, one of them is about 4mm off so the thing wont mount and the holes are drilled too far back, for the bolt to go through. I think you should update your jig, guys. :P
Sorry man, but you fixed it?
Yeah i got it to fit, took alot of hammering and grinding tho. And when i got it to mount the subframe was wayy off line with the rest of the bike, a lot of hammering later tho i got it a bit in line.
Its not that big of a deal to me but if someone doesnt have the tools and or knowledge of what to do when they order a subframe and it doesnt mount theyre going to be pissed. You really should change the desing of the subframe a bit, for an example if youd weld tabs to the end of the pipes where the subframe mounts to the frame it would take out the grinding.
I dont know of the making process of the subframe but im guessing you tap the parts in place on the jig and then take it off and finish the welds? If so thats what makes the subframe bend out of line. And this is not just a one time deal on my frame, my friend had the exact same problem on his subframe.
Hope you get it in shape, im a bit scared to order anything precise from you like a hand brake bracket, cause if that is off its going to fuck up the rear rotor and the brake pads, and it wont even work. Hopefully you get this stuff in shape.
Quote Originally Posted by Lolletroo
Hello,
thanks for advice and once again sorry for all this extra work!
I'll give you some discount on next order for sure.
Triumph 675 Street Triple parts like crash cage, adjustable subcage, rearsets, roundbar and big rotor kit are already available. Check them out!
http://www.forstunt.home.pl/pl/new-products
Aluminium HB bracket and adapter for 300mm disc for Honda F4i
http://www.forstunt.home.pl/pl/honda...arcze-f4i.html
Ok so I'm pretty fuckin pissed I posted before about how this bracket took a while to come also the website never stated which caliper to run as it said left or right and that was not correct I said ok it's a little mistake I'm not one to go crazy over something stupid. Well I finally got it all set up with my nissin 4 piston caliper AS STATED and looked good mounted alrite a little twisted but would work. So I tried bleeding the brakes and I sucked so had no power well I went to the lot got some tips and today rebled my caliper and it was good to go rock hard and I guess from the power it snapped your bracket I never even did a wheelie with this shit. This snapped just tested the brake pulling out of my driveway. Now I would like to know if there is something we can work out here? I'm not happy at all with this product and would like to get my money back I have pictures to prove it.
Fuck that's bad! Trust me or not but that never happened before...
I can make a new one and send to you or send your money back. Tell me what you prefer
Hey speedy thanks for the quick reply I would much prefer my money back. I really appreciate it. My Paypal is bikerboy570@yahoo.com
