CliffHangers????
CliffHangers????
#21
\r\n Originally Posted by Stick\r\n View Post\r\n
Hey now, what\'s so bad about dot 5?!
you dont want to put dot 5 in ure bike i believe 5 is for cars ure manual will tell you to only use dot 4\r\n
\r\n \r\n I\'m running 5 in my HB and FB and it seems fine. There\'s even a picture of a bike on the bottle! lol\r\n
\r\n \r\n u should get it out asap dot 5 is silicone based and your not suposed to run any silicone based brake fluid in your bike\r\n
\r\n Originally Posted by Bortner\r\n View Post\r\n
+1 I wouldnt risk it. I always use the brake fluid that says capable with dot 3/4. That is silicone based.\r\n
better buy a rebuild kit for your masters doggy..\r\n
\r\n \r\n Whaaaaaaaaaaaaaaat?!!!!
\nEDIT: Seriously, why not? Ryan S. said he\'s been running the stuff for years without any problem. I know you\'re not supposed to mix 5 with 3,4, or 5.1, so as long as I\'ve flushed out all the old fluid why would there be a problem? (not trying to sound arrogant, just trying to learn)\r\n
\r\n \r\n Yesir... dot 5 no good. Crystallizes inside and blows grommets. Go dot 4 racing fluid. I prefer RBF600. But any dot 4 will do.\r\n
\r\n \r\n I have seen it first hand ruin a seal kit in a brand new magura.\r\n
\r\n Originally Posted by GIL with 1 L\r\n View Post\r\n
Could be rad overflow
thought about that but the overflow up there wouldnt make to much sense to have the overflow up there, plus the only red antifreeze i know of is VW, an its more pink then red\r\n
\r\n Originally Posted by Will215\r\n View Post\r\n
So you are saying every mod you have seen makes sense. It\'s probably power steering fluid\r\n
