adjusting secondary butterflies on 03-04 636
#21
\r\n Originally Posted by ATL Darrick\r\n View Post\r\n
just pulled out my manual and it says for adjusting that, you have to hook up a volt meter and adjust it by hand until the voltage is within spec.....you can also check it from the ecu.
\njust need to get my hands on a volt meter and someone that understands voltage a little more to help me.....i\'m terrible with electric
what page in the manual is it? i wanna check mine out when I start piecing this bike back together \r\n
\r\n \r\n I tried this mod around 3 years ago and it robbed me on the low down. The throttle response was terrible. I am going to have to look in my manual and give the sync a try.\r\n
\r\n \r\n where was you idle set when you looked at them compared to the other bikes you looked at ?
\ni dont know for sure but i would assume they would be open more if your idle is at 3500 rather than 1000..\r\n
DOH that would suck if thats what it was lol. he did say he had a weak idle pull tho compared to other 636\'s\r\n
\r\n Originally Posted by OnEWhEeLNEAL\r\n View Post\r\n
i may be completely wrong they may go to the same position when you turn the bike off no matter what the idle is set at it was just a thought \r\n
Ima check that out tomorrow but good suggestion it might be something that simple \r\n
\r\n \r\n I think idling the bike to wherever you set it at should only control the primary butterflies. i also have my idle turned down everytime i get off the bike.
\r\nmy theory of doing this adjusting is just another shot in the dark to try to figure out whats wrong with my bike.
\r\nneal, the section in the manual is 3-95
\r\nandy, yeah i know you told me, i just didnt want to have to do it lol\r\n
\r\n Originally Posted by reds919hornet\r\n View Post\r\n
if you can get up to calhoun with your bike and manual i have a good meter and do good with elec. stuff.
thanks for the offer. i\'ll let you know\r\n
any time. you can ask borne who i am. i had an auto repair shop next to jrd when he worked with rick.\r\n
\r\n \r\n D Feel free to come by and try my ECU if you think that will make a difference... You cant have it... but atleast we will know if the ecu is off...
\nOMR he compared my TB secondary butterfly position while both bikes were off.... His had about a 3MM gap and mine were closed all the way... My bike pulls like a champ, his doesnt pull good at all.
\nWe have compared almost everything else on the bike and i know he has tried various other fixes.. Fuel pump, Air filters, Gearing.... You name it nothing has fixed his idle pull. the bike has a very fresh motor on it, and it should pull great!\r\n
